leroy
I disconnected the vacuum line from my 3 bar MAP sensor today, and hooked up a mityvac. I also teed a larger Sun vacuum gauge into the line to check accuracy. I hooked up Diacom, started the truck and used the mityvac to adjust the vacuum applied to the MAP sensor.
I recorded the results in a spreadsheet at http://www.sunflower.com/~leroy/diacom_vacuum.htm . Measured values are in black. Predicted values are in red.
The first row shows the vacuum reading in Diacom.
The second row shows the MAP reading in Diacom.
The third row shows the vacuum gauge reading in inches of Hg.
The fourth row shows the calculated absolute pressure in kpa, based on the gauge reading.
The truck stalled when I got to 19 in Hg on the vacuum gauge, and the truck must be running, to record map values in Diacom. When I have some more time, I'll do some tweaking to complete the chart and add a row for turbo boost pressure.
This may be useful to some when tuning the F29 table. I was using a conversion equation before, that wasn't quite as accurate.
Jim
Jim
