Did tune up.....LOST power!?!?
WS6Clint
I did a tune-up yesterday that included plugs, wires, cap and rotor, oil change, fuel filter, K&N air filter, and I also replaced my heater core. I also removed the ECM fuses and reset it. Now it has kind of a backfire, more like a puff in the muffler, and is very sluggish. Tried to launch and it would not build more than 3lbs of boost. Also will now not build boost if i let off the gas then back on it when at speed. Forgot also put fuel injector cleaner in the tank. Any help is greatly appreciated.....
Clint
GM TURBO
Sell Out
Ignition, Ignition, Ignition.
Either that or a vaccuum leak somwhere. But I would say chances are ignition is goofed somewhere.
I hope to not be asking the obvious - what plugs did ya use?
WS6Clint
I will check my vaccum hoses, I used CR43TS's, I know I know, don't brow beat me. I have ordered UR6's. Would those plugs cause thet bad of a problem?
Clint
GM TURBO
Sell Out
DOH!!!
It shouldn't cause that much of an issue - in my opinion, But then ignition components shouldn't have to be replaced every 5,000 miles either.
I ran Rapidfire plugs and had similiar problems as to what you have. If it were crossed plug wires it would run extrememly bad - if at all.
So, I could ask the next questions and you better have the RIGHT answer this time - or at least not the wrong one ;)
What Cap & Rotor?
What wires?
One thing to test I guess would be to put the old plugs back in to see if anyhting changes. The hard thing about this is a lot of things changed all at the same time. About the only thing that I would put a decent amount of money on would be ignition. Check and make sure all plug boots are securely on the plugs and cap.
Oh - if you answer Accel to the two questions - I am done helping ;)
smeagol
I think you found your answer, and the reason people are browbeated when they use those plugs when forewarned by every syty web resource ;)
Loeryder
And get the UR5s if you are running near stock level boost and FP.
UR6s are one step cooler for trucks running bigger turbos higher boost, more fuel, andything that can help reduce knock is only a good thing.
CR43TS are a hotter plug and induce knock. If you have a scantool hooked up check your knock retard. You may be bitterly suprised.
I 2nd checking EVERY wire and plug to be sure they are seated properly, also check your dist cap to be sure it is screwed down tightly. If you've never done one on these trucks they can be difficult to start the screws.
4C FED
Absolutum Dominium
What about ignition timing?
Did you disconnect the "tan wire" & check the timing after you replaced the cap & rotor?
I remember when I was messing around with my dist. If it is retarded you will build very little boost and it wil be very s l o w to spool.
4C FED
Absolutum Dominium
If you look at the pic from Tookycat (this is the timing pointer on the timing chain cover), where the redline currently is, the timing is slighlty retarded.
It should be be slightly more to the left, in the middle of that first peak.
WS6Clint
OK, I changed my plugs and wires today and put the right stuff in this time. UR6 plugs and Accel wires(graphite, the damn cut to fit kind) and I still have the same problems. Could it be the STP fuel injector cleaner I used? I am going to try to check the Dist. cap and timing tommorrow. In the mean time any input is very welcome.
Confused in Tennessee,
Clint
InvisiBill
A lot of SyTy-ers have problems with Accel ignition stuff (even stuff that works great on other vehicles). I'd go with the SyTy tried & tested parts just to make sure. The Taylor Spiro Pro wires seem to work quite well and are relatively cheap compared to other "performance" wires. 074232 is the red kit for SyTy's (even though it says 8 cyl) and ran me ~$40 from Summit. You can get other colors by changing one digit in the part number, but I'm not sure which one it is.
You also have a higher likelihood of problems if you have to cut your own. While it's possible to get a bad wire from the factory, you've got 14 connections that can go bad. I've heard of some people having just a bit of wire sticking out and grounding on the exhaust...
As someone mentioned, the cap can be tricky too. It is possible to screw it down fairly securely with it misaligned a bit. That never helps anything...
