Died and won't restart
Mikes93Ty
This is my first post here so I hope i'm in the right forum, but heres my problem. I had my Typhoon idling last night and it just died and wouldn't restart, narrowed it down to fuel pump, only turns on when you hook up the test wire to 12 volts. Hooked my multimeter to relay and connector at tank with the purple and gray wires, all wires except the purple have battery voltage that wires at like 8.6 volts is my fuel pump shot or do I have a bad fusable link. My dads 98 Sonama's pump just went out last week and he said thats what the mechanics did to get it started again so he could drive it to shop to replace the pump. Thanks for any help you guys can provide.
Captain Morgan
Moderated User
there are no fusable links in the system. if it is fuel pump related, its one of 3 things.
1. the ECM-B fuse under the dash
2. the fuel pump relay on the fire wall under the hood
3. the fuel pump inself
GM TURBO
Sell Out
ECM B Fuse.
You should get fuel prime when you first click the key over. If it doesn't do that then the ECM doesn't have power.
Mikes93Ty
Is the ECM B fuse the one in the bottom of the fuse block labeled ECM or is it somewhere else under the dash, that fuse is good and the truck runs if the test wire is hooked to 12 volts.
SY2932
Administrator
Based on that, swap the AC relay with the fuel pump one (they are the same) and see if that's the problem. The AC and FP relays are mounted on the firewall next to the brake booster on the drivers side of the truck. The AC one is next to the brake booster and the FP one is next to the fenderwell. HTH's
Mikes93Ty
Thanks for all the help guys, got it fixed put in new Walbro HP 255 pump and new relay, but now another problem came up, the Ty's not boosting like it did before, now I only get like 5-8psi, before the stock gauge would go all the way to the 15psi mark. Has a new boost solenoid and vacum hoses. What did I do now?
