Died on fwy
ROSEDOGGYDOG
umop apisdn w,I
Coming home from the airport sunday, I'm cruising along at 60mph in the right lane talking on the cell, when out of the blue, my engine cut out (no sputtering, no noises, no thinking about) and the check engine light came on! Once I coasted to the side, I tried to restart it. The ignition was firing but the motor wasn't cranking over. Popped the hood and checked for any wires that may touched the block but I didn't find any.
Do we have a timing belt or chain? If belt, thats what I'm thinking it is (seen it happen to a friends car before). If chain, I don't know...
Fuel pump was replaced by the dealer a few months ago, coil is about a year old (MSD blaster). Anyone have any ideas as to what it might be?
smeagol
How could the ignition fire without the engine turning over?
Trace it back, do you have power when you turn the key? If not, problem is electrical with the battery... do you have fuel pump prime at key on?
Considering it sounds like you have power, I'd blame it on something electrical/ECM. Only confusing thing is that your engine doesn't crank over if what you said above is correct? Please clarify your statement.
ROSEDOGGYDOG
umop apisdn w,I
Sorry, I meant TURNING OVER... :oops:
Yes I have power, as to "have fuel pump prime at key on?"...derr...huh? what does that mean? If you mean, can I hear my fuel pump when I turn the ignition to power on, then yes, if not I don't have a clue.
2nd time ECM has been mentioned though...
ROSEDOGGYDOG
umop apisdn w,I
well good news for me, it was the fuel pump (that was just replaced by the dealer, where the truck is at now) not gonna cost me a cent!
But I my question to the ECM has not been answered, anyone want to chime in on it?
LuvBoost
The ECM-B fuse has a tendncy of blowing after a fuel pump upgrade. IE a Walbro. They pull more current. Swap out the 10 amp for a 15 and you are good to go.
InvisiBill
A few hours. Pull the bed off, unhook four hoses and the wiring harness, turn the locking ring and pull it out. Reverse for reinstall. It's really not hard, things can just take a while. I sprayed the line nuts and locking ring down with GM rust penetrant, and everything came apart like it was brand new when I got around to that part...
GM TURBO
Sell Out
Bill-
I think he is talking about how long would it take to replace the fuse since the dealer is gonna replace the fuel pump for free. It is on a SoGT so the Walboro isn't really gonna be needed.
Fuse - find the fuse box. It is on the driver's side directly above your left leg. Find the fuse labeled ECM B - it should be a 10A - replace it with a 15A. You might not need to since this is a common problem with sticking a Walboro in and you are going with a stock replacement. If this fuse were to blow - you would experience the same problem - but you wouldn't hear fuel pump prime. Always a good idea to keep a spare in the truck with you. It will take 1 minute to replace including locating the fuse box for the first time.
