dies at idle, stumbles..
91blazins10
Ok ive been dealing with this problem for a while, I have the ultimate chip for stock injectors its seems like when I bump up the fuel pressure to base 50psi it just doesnt run right, with the stock chip I run it at 39psi base and it runs fine, just changed the oil yesturday and the old oil smelled like gas. Ive read some problems with the vac line leaking gas on the fpr, so i checked that and its not, so im thinkin injectors leaking maybe? It seems like it gets worse as it gets hotter, when i drive it light footed theres really no problems but when I floor it, it just stumbles and the check engine light comes on and off very fast, and it will backfire. At idle it will be ok sometimes and other times it just dies. Im gonna run datamaster tommrow and post the file, so someone with greater knowledge of the program can look at it. meanwhile please post if you any ideas thanks.
wantingasy
Re: dies at idle, stumbles..
Sounds like you're flooding the engine and that's what is causing it to stumble. I would check datamaster and see if it's running rich or lean. I would bump the fuel pressure down to like 42 or 43 at idle with the vacuum off.
sleepy
If i thas backfired - make sur eyou check all your vacuum lines - they tend to blow off if the backfire is severe enough - a woul dalso turn the fuel pressure down some - do the easy stuff first... Good luck
