difference in feul-lines.
bezerk
So after 1 hour of struggeling to get my new engine in, it finnaly came in rigth.
So connecting all things i noticed one difference in the feulline between Syclone and Typhoon, or maybe it is year related.
The retour-line is shorter than the otherfeulline that was on my other engine.
So did annybody has seen this before??
ed hess
race or get outta the way
yes
on a sy the return is shorter than the feed line
I think a mechnaic musta bitched about the feed line going over the top to the higher ups that if the fuel rail came to the back of the motor the feed line wouldnt be as easy to kink doing an R&R on the motor.
Must suck be a gm mechanic cuz they have to replace it with oem stuff wereas we get the easy solution of ss line and an fittings.
ed
bezerk
Than the guy from wich i bought the engine was telling the truth that it came from a Sy.
To bad it took me about 15 min to swap the line including injectors.....
So hopefully my Ty will run strong with a new block and turbo, after the mission is oiver :p
