Difference in idle speed in P and D
Falco
Howdy,
I'm just curious what's the reason between the different idle speed settings under load and not under load. The Ultimate came like this and would be nice to know the reason. With the 50's it's 800 at idle once warmed up and no load (in P). It's 700 under load.
I guess it's because Brian wanted to make it easier for the drive train under load. Is that right? Can I raise these numbers a little, or make them the same?
Thanks,
sytyguy
Moderated User
My drivetrain seems to "engage" easier when I have an idle rpm drop from P/N to D. Meaning....there seems to be less "clunk" when it goes in gear. However, if you have electrical drain issues (large electric fan, etc....) that may cause the truck to die when it idles that low in gear, it may be necessary to bump it up.
BG will prolly chime in here shortly.
Michael
smeagol
Well, it has a lot to do with idle tuning.
There is no way to run different VE at idle in park/neutral vs drive (other than scaling the VE at different RPM I mean). Obviously the load is higher when you are in drive, so if all else is equal (idle speeds) something needs to change, to maintain stoichiometric.
I have discussed this before, and it's a bit difficult to put into a comprehensive post to clarify for everyone.
I tried to come up with a *good* way to sort this out, create some way so the fueling was a bit leaner in park/neutral. Scaling the VE versus RPM & map doesn't really cure it, since the idle speeds vary based on coolant and such, and such fine resolution just isn't there. Creating new tables and whatnot is just too time consuming for such a small issue. I looked at how the factory dealt with this issue, and basically how it was done (I assume) was this: the idle was tuned in drive, to stoichiometric. IAC counts and such are kept in good range, and the idle is tuned at all idle speeds & conditions (in drive). The VE was then tuned in park/neutral by merely adjusting the idle speed until it could run at stoichiometric. So this is why all of the stock calibrations have idle speeds in drive that are lower than in park/neutral. It doesn't make sense to idle the truck higher in park/neutral than in drive - you'd want it more stable in drive, with more load being placed on the motor.
So you can raise it, but I'd increase both values by the same amount.
Also, the other reason for the lower idle speeds in drive - if you have it too high, it can start lugging the vehicle forward with a tighter converter.
Also, for those doing FAST or other aftermarket ECU's tuning... most don't have a park/neutral input... try tuning the idle of those ECU's...typically you have to set the idle in drive so it is stable, and just deal with whatever the fueling is in park/neutral, since the load varies so much on the engine, but the manifold pressure/rpm change isn't significant enough to allow VE map changes to account for the fuel needs changing (say what???)
I tried a LOT of different changes to help with the idle... all sorts of idle speeds, all sorts of maps, timing, timing changes, IAC parameter changes... and the cal that you are playing with gave me the smoothest idle I've ever had, period.
Falco
I appreciate your input. Thanks for the detailed explanation Brian!
I'll raise my idle, but will keep the ~100 RPM difference. This tries to be a workaround for my hunting idle/stalling problem. Once I found the solution I'll go back to the original settings and tune from there once again.
Thanks,
