Differences in FAST and FAST XFI? ---
alwayscode390
pppssssshhhhhtttttttttttt
I have an older FAST, and wasnt sure if the NEWER was worth upgrading to?
If anyone has knowledge of the differences between the two, please post here, THANKS :) ---
Windedv6
Ty n 10s
Re: Differences in FAST and FAST XFI? ---
I have an older FAST, and wasn’t sure if the NEWER was worth upgrading to?
I have them both. My AWD Typhoon has a Fast (classic) and my TT Typhoon has the FXi. While there are numerous differences the basics that both have can handle our fastest builds (no pun intended). The extras the FXi has is the sophistication to do many extras such as link to other electronics such as dash monitors, “E” trannies, multiple sensors and inputs, such as analog inputs. It has abilities to run flex fuel setups, basic boost control table, a more sophisticated nitrous control, plus others.
Here is some Q an A from the FAST site…
Q: The XFI™ system incorporates a lot of new features and capabilities that the original system did not offer. Can you list some of the new benefits?
A: The new C-Com WP XFI™ software version features 10 new start-up tunes to choose from and allows you to keep 4 different tunes in your ECU that can be selected through a remote switch. The XFI™ also incorporates a Fuel Energy Constant feature that will allow the user to select the fuel type, including E85 fuel, or the use of a common Fuel Composition Sensor for true “Flex Fuel” capability. In addition, the XFI™ supports many OEM and racing applications straight out of the box and can be programmed for bank fire or sequential operation. Turbocharger boost control, trans-brake control, EGR control, and a comprehensive “Power Adder” control system are also standard XFI™ features. Internal data logging is now a new optional feature that eliminates the need for an external storage device to log data. XFI™ software updates are available at www.fuelairspark.com at no charge!
Q: With the XFI™ system do I need a separate data logger?
A: The standard XFI™ ECU can log data from up to 24 sensors and record this data to a laptop that is connected through the communications cable. One of the optional upgrades for the XFI™ is an internal data logging feature (Part #301423). This option will allow the recorded data to be stored in the XFI™ unit and downloaded to a laptop at a later time. This eliminates the need to have a laptop in the vehicle while recording data. Any XFI™ can be upgraded with the internal data logging feature. For the ultimate real time viewing and data logging of engine and vehicle data, we have a Touch Screen Dash/Data Logger (Part #301417). This, along with our wide range of auxiliary sensors and data acquisition hardware, will allow the user to view all engine and vehicle data on a touch screen display. This recorded data can be played back on the touch screen or downloaded to a laptop for graph viewing in the C-Com software. The dash receives all engine data through a two wire CAN (Controller Area Network) connection with the XFI™. The Touch Screen Dash/Data Logger can record up to 1 hour of continuous data and has many other useful features.
Q: Can options like Intelligent Traction Control™, internal data logging and 16-injector capability be added to a basic XFI™?
A: Any of the XFI™ options can be added to any XFI™ ECU, and the firmware in the ECU can be re-flashed without even removing it from the car. Call our FAST™ EFI HELP™ line for information about upgrading an existing XFI™ or flashing updates.
In my opinion, unless you are needing something special such as E85 control, multiple tunes without connecting the laptop, data logging without having the laptop, you can tune the classic to do anything you want your truck to do. If you are not familiar with and do not want all the extra complications then get a used classic for ½ price and you will easily be able to self learn it. The FXI can get very complex if you want to go beyond the basics needed for our type of tuning.
John
blk00z28
Forced to by choice
The classic can't control a lot of the things the xfi can. Like for example, shift points. You'll have to have a stand alone box to control tranny shifting. TC lock up's will have to be controlled by the stand alone box as well. Electric fan's cant be controlled by the classic. The AC won't be able to be controlled by the classic. All of which the XFI can do. But is it worth spending (I have been quoted this price for everything, harness's and box) $2400 on?
Mark(Maxtor) has the classic on the stokes truck and it works well together with the trans controller.
When the XFI came out, people were selling the classic boxes dirt cheap. Hell you cant get one for under $800 now. I don't understand why. Because unless its an HEI ready box they can't be converted. The one guy who used to do it no longer does.
Windedv6
Ty n 10s
A couple of corrections...not to hurt your feelings though.
The classic can control the fans and AC. Neither the classic or the fxi can control shift the points without the stand alone trans controller. The fxi still needs the trans controller. It is that the fxi can then control it through the CAN connection between the trans controller and the fxi box.
Maxtor has a 700r4 not a e-tranny. No trans controller needed.
John
