Re: Dipstick/4 bolt mains
I ground a groove into the cap where the tube enters to provide clearance & some s l o w, careful bending.
Don't forget to install the dipstick tube before you put the exhaust manifolds on. It makes it a lot easier to get the dipstick tube installed this way.
To bend the tube, I inserted it into the block until it hits the cap. You can approximate where it needs to bend by looking at where the tube hits the cap.
Pull the tube partially out until where you want it to bend is just exiting the hole in the block. Remember you want the tube pointed in the direction where it normally points, towards the front of the motor.
Now pull on the tube, slowly outward, away from the block, just a little.
Push the tube back into the block and see how much more you need to bend it & where it needs to bend.
Continue until the bend is sufficient to clear the cap.
