disc conversions
blackty
What do you guys think of using the '98-'02 ls1 12" front discs and then the '98 ^ rears from an s-10? There has been alot of discussion about the rears locking up on wet roads with the larger 12" discs on the rear. Changing proportioning valves and using adjustable valves to dial in equalization seems more like an opportunity for failure. Just random thoughts before I change mine this winter. Thanks for your thoughts...Jim
warmpancakes
Re: disc conversions
the s10 parts are more expensive to repair, and a little smaller, you need to add a adj prop valve
blackty
So just go 12" all the way around then? What do recommend as far as which adj. valve to use? I thought I was on to something there, less bite in the rear, no lock ups. Thanks...Jim
sytyguy
Moderated User
I sell the 260-8419 for $39.99.
Summit's link - http://www.summitracing.com/parts/WIL-260-8419/
warmpancakes
thats the one you need also if you do hoods abs delet kit where the front lines connect at the bottom of the firwall is can fit right there and its out of the way
blackty
Thanks guys. I already have Rob's delete kit. (on the shelf) Any rule of thumb as how many turns of the dial, or just find that wet parking lot? Mike, I'll hit you up in a little while for that...Jim
sytyguy
Moderated User
Yeah, like Ken said....
We usually (on race cars) find a stretch of open road and get up to 30 mph and lock on the brakes....adjust till rears lock up just before fronts. Get up to 50 mph and repeat.....Get up to 70 and repeat....etc...
sytyguy
Moderated User
I was just informed that Summit offers a rebadged Wilwood valve for $3 less than the Wilwood one, so.....
I will honor that price - $38.95.
