Disconnect WG on Ultimate 50#?
bjzq8
I'm about to get my Ultimate 50# delivered (gauge style.)
I (will before the chip goes in) have 50# injectors, AFPR, Walbro, functional IC pump, etc...and I've done all of the "normal" maintenance stuff to get ready for the Ult. I'm just wondering...in the latest version of the Ultimate, should I pull the electrical connection on the boost solenoid? I don't want to run 18 psi out of the box on pump gas (since there's really only 18 or 22psi boost control now)...or do I? Or perhaps I'm completely mis-understanding the blurb on the 50# ultimate? It's stock turbo, stock heads and cam right now.
Bill Jenkins
1992 Typhoon
bezerk
It would be nice if somebody answered,
I''am about to buy some stuff, and i can't figure out what to do.
Walbro 340 Feulpump
FPR
3bar map sensor
IC lines and pump
Tockturbo wastegate Etc.
Is it a good ID to buy STG-ultimate along with the #50 injectors??
or is it a waste of money??
Rene
leroy
You shouldn't need 50# injectors with the stock turbo. If you have the extra money, and plan to upgrade the turbo in the future, buy the 50# injectors.
HTH,
Jim
bezerk
So it doesn''t help a lillte bit??
It''s real hard to look in the future, but i just had a rebuild of the turbo, that''s why.
But if i''am going for the stockers, wich Ultimate should i use?
i heard there are 2 versions, leanfeul and richfeul right???
Rene
ZMann
vertically challenged
I believe Todd A. and BG have a nice ultimate for stock injectors, etc...
They recommend afpr and fuel pump with it. PM them.
If ur staying with a stock turbo, no need for 50's. But if u plan on going bigger turbo wise... get the 50s.
Later
Zach Mann
Sy1012
InvisiBill
Walbro 340 Feulpump
FPR
3bar map sensor
IC lines and pump
Rene
To use a 3-bar MAP sensor or different injectors, you need to have a chip calibrated for those parts.
If you want to be able to see over 15psi, you need a 3-bar MAP sensor. If you want to use a 3-bar sensor, you need a 3-bar chip. Which is basically the Ultimate or a custom one from someone else on the board.
There are people running 11s on the stock injectors. Basically, if you're going to stay with a stock turbo, you don't need to upgrade the injectors. The 50# Ultimate is tuned for modified engines as well, so it's really for the "big boys"...
ty1548
I would definitely recommend sticking with the stock injectors based on your list of mods. Down the road if you get to the point where you really need the larger injectors, the chip can be upgraded for a nominal fee to reprogram the display and EPROM for about $40. I'd recommend the leaner version (v8) since you still use the stock turbo. If the turbo is coming out anytime soon go with v9 which runs more fuel for a combination of larger turbo, I/C, exhaust upgrades.
tyguy93
Hoi, Rene, Hoe gaat het met jou en Nederlands, eh?
yeah, if you are running stock turbo right now, stock engine, you'll be fine with the stock injectors and running the STG Ultimate. It is also a good idea as mentioned in early message to disconnect the boost solenoid.
Here's a page from Brian, that helps explain some of the items ont eh 50# chips:
http://www.chitownsyty.com/bg/chipstuff/50v2.htm
beste wensen voor de toekomst!
pd van amsterdammer
bezerk
maak me gek!
is dit een zonnesteek, of zijn er mensen uit nederland!!!
vertel,verklaar en etc..
Sorry for the language guys!
