why do i do this?????
A ABLITZ Damn Yankee Mar 7, 2002 #2 for the timing right? its under the dash on the passenger side.u gotta take off the panel under the dash to get at it
B bigjohn New member Mar 7, 2002 #3 to set the timing you will need to disconnect this wire. all you need to do is pull the carpet back. un plug the tan wire, set your timing to O then re-connect the wire. if you don't un-plug the wire first you will be way retarded! get it?
