E.Murray
Please tell me I'm wrong... I took off the oil pan and pulled the oil pump to check it (problem turned out to be distributor gear). Got the bottom end all back together yesterday and filled with oil. Last night I went to reinstall the distributor. When I dropped the shaft down to connect to the oil pump, though, it seems too big to go though the hole above the oil pump... Which would mean it has to go in from the bottom... Which would mean I have to tear apart everything again to pull the oil pump back out. :rant::rant: Please tell me it can be put in from the top.
