Distributor/Coil Operation for a cutoff switch.
I trying to cutoff my igniton via a battery switch. I planning on using a relay. My best/easiest idea so far is to put a relay in one of the wires in the 2 wire connector that goes from the ignition coil to distributor. (I am familair with relay operation) I assume these 2 wires tell the coil to fire and if I interupt one of it lines (when the relay is off) I think it will kill the truck right. Does this seem like a good solution?
As for the relay should I try to integrate my ignition switch to turn it off and on, so the relay is not on most of the time? Or should I just ground it and use the power from my battery switch to power it and leave it on when the kill witch is on?
You would want it normally open so that you need power to close the relay and the coil circuits. That way would probably be the safer route.
I'm thinking of doing sort of the same thing, but having a contactor to change between the stock coil/ignition to the 7AL/HVC coil setup. The MSD stuff is for race only and likes to break up after getting too hot. I would like to drive with the stock stuff then switch to the race stuff only when needed without opening the hood and moving the coil wire and harness adaptor.
This got me thinking, I was eventually going to install my MSD6AL that I have laying around. Maybe I should install the MSD cut the power turn on which would be easy enough.
