Syclone#2960
What ever it takes!!
What is the shaft diameter size needed to replace the stock distributor gear? .491" or .500"?
You still have your engine out, right? How about measure the size for us.i need one of these suckers to for the stock distributor.
so is it a .491 needed or .427 needed for the stock distributor?
I would be interested to see exactly what a stock (not reman) distributor measures out to. I can see some some reman companies (A1 Cardone, etc...) using a different gear if there was excessive wear there, or if lathing the shaft was part of the reman process for them. Would be weirder if GM used a different gear just for 4.3s when it only varies slightly from the standard SBC distributor used in a billion other engines.Or read the thread :roll:
He already said that .491 doesn't work...
Stock is smaller size, you won't notice that unless you actually pull the gear off.
