MIGHTYMOUSE
Turbo F body guy
i am reading that on some older models there was no 'bypass' connector, and that the entire 4 pin dist connector would be removed to set base timing
do you think our trucks would still fire and run (on base timing) if this 4 pin connector was removed completely? from what i have read its job is to only influence the base timing as the vacuum and weights used to do.
if i could eliminate this connection from one of my problems it would really help
