DIY Turbo heat shield
SYO237
SyTy Registry
Re: DIY Turbo heat shield
Mom is gonna kill me when she finds out I came over and swipped her dishes.
Good post. Another thing to add to the project list now.
Jer
Don't taze me bro!
Wow... I'm on that forum on a regular basis. How did I miss that?
Ty1642
I decided to give this a try with my PTE turbo. Mainly because the turbo to intercooler pipe I put together ran very close to the turbocharger. Here are a few photos for anyone else that might want to try.
After measuring the size of the turbo, I found this stainless steel canister at Target. I cut up the coolant bottle to make a template as I went.
Here is the label on the bottom of the canister. It even had the diameter listed. They had several other sizes also.
Here is the canister after cutting the top half off. I cut it 4" up from the bottom using a hacksaw, with tape to protect the finish on the half I was keeping.
After cutting the bottom half into two pieces. The sides opened up when it was cut in half, so I had to bend it by hand back into shape. If you look close, the half on the left is bent back to shape, and the half on the right is the way it deforms after cutting. Later on, I found out that a complete 180 degree half didn't quite fit, and cut some more off.
After cutting for clearance around the center of the turbo and drilling mounting holes. I have to confess even after measuring two or three times, my holes didn't line up with the bolts in the turbo. I ended up enlarging the space around the middle bolt so the shield fits around it instead.
Shield installed, before putting the turbo to intercooler hose back in place. It mounts using the bolts on the back half of the turbo.
With the turbo to intercooler hose back in place. The shield gets pretty buried under everything else, but hopefully it keeps some of the heat away from the intercooler and engine compartment. In the end it looks pretty good too.
For anyone else that tries this, I really suggest measuring carefully with a template made from something easier to work with. Also get drill bits and other tools that can handle stainless steel. This chewed up a handful of bits and dremel tool mill / grinding tips. All in all, it probably took about four hours using hand tools.
blk00z28
Forced to by choice
Nice work man. (And nice find for the orginal posters)
Can you by chance get any pics from inside the wheel well? If you get some time that is.
AlaskaTy
That's cool that you just ran with the idea and pouned it out. I find a lot of cool ideas out there but always file them in the "to do pile". Looks good though.
jollygreen1964
Along these lines has anyone had either or both sides of the turbo ceramic coated, also the downpipe?
sharkbait
that was a great idea. you should sell them.
canadian
sy in progress
What did you use to make the cut?
"Here is the canister after cutting the top half off. I cut it 4" up from the bottom using a hacksaw, with tape to protect the finish on the half I was keeping."
Mario65
Hotrodicus Supersonicus
The more I look at this the more I like it.
Hack saw? maybe the inital cut
what would you guys use to make the precise cuts?
Here's my setup.
http://tyfab.transams.net/TYFAB-Pages/Image24.html
Is it a common setup?
I was wondering if it is maybe we can get someone to fab a bunch of them.
I will do mine unless someone out there is ready willing and able t make a little money.
mario
Ty1642
The hardest part of this mod is getting the mounting holes in the right place. It's a pretty tight fit between the turbo, the CAC, and other oil lines and brackets. I originally used half of the canister (diameter), and that wouldn't fit over/under/around everything - it had to be cut down some more to fit in. Then the holes have to be marked where they line up. Once you had made one that fits, turning out more would be easy. Keep in mind that mine is for a PTE turbo - the stock turbo probably has a different mounting bolt arrangement.
I'd make more if I had the right tools. (I really did use a hacksaw to cut the whole thing.) Working carefully, it did come out fine, and the cut edges are down anyway. Cutting stainless with a hacksaw is a pain in the *ss though.
Mario65
I went to 2 targeys and every other store my wife recommended and couldnt find a 6-6.5 diameter pot. I will have to use a utensils hodlder that looks perfect but is not polished. It was cheap but I will have to polish it. I got it at Ross. I think I will mock it with cardboard and let a metal fab place make the cuts.
Aeroking
e.i.
turbo blankets are cheap, and they're cool to the touch after a 30psi boost run. :2cents:
thewumpus99
True, but a turbo blanket can turn into an instant engine fire if you get a pinhole leak of the wrong fluid spraying onto it!
