DIY w/b warm up times.
TurboTony
Hey all,
I'd like to shorten the warm up time of my W/B a bit.
I have a good voltage source to the w/b but it takes a bit too long to reach operating temp.
The diy w/b site talks about adding shunting resistors to R4 but it doesn't give a value.
Anyone know what resistance and wattage I need to do this? Does it need to be a large ceramic resistor like R4(1 ohm 5 watts). Do i need to attach the shunting resitor to the cover also?
Where is that redneck electronics expert when ya need him? :D
TIA
Tony
leroy
Start by adding a 10 ohm resistor in parallel. You may have to add 2 or 3 to get the warm up time down. Extra resistors were included in my parts kits, but I got one of the first ones.
Jim
myclone
Re: DIY w/b warm up times.
TIA
Tony
You rang???? :p :D
Lemme dig out the skeee-matiks and see whats up...
Lemme see.. Looks like you could add resistors in parallel to R4 but they would need to be the same wattage as R4 (big honk'n 5w). If youre feeling adventuresome you could prolly lower the value of C1 the soft start cap. This should shorten the time constant for the heat to come up to temp IMO. If it was me Id try a 5 microferry (microfarad for you non smart ass ppl) and see if that shortens the time up to where you want.
If thats too short then add a another cap in parallel to the 5 microferry to slightly bump the value up slightly. Like a 2.5microferry or close to it which would give you 7.5microferries. Remember caps work the OPPOSITE way of resistors in series/parallel. Caps in series subtract (basically) and caps in parallel add in value.
leroy
I'm not an electronics guru, so adding the 10 ohm resistor came from the diy-efi archives. It was one of those things I noted before building mine. I think I had to add at least one resistor to both of mine to get the warm up time down from around 2-3 minutes to about 30 seconds. IIRC, warm up time should not be much faster than around 30 seconds, but not sure why......maybe something about not letting the smoke out. :D
I'm guessing Dave's method would work as well.
Jim
BigAl...
this is some pretty cool stuff. Tony you should email peter at tech edge he helped me alot when I was working on mine.
BigAl...
E-Rue
on mine, it seems like the sensor takes a while to heat up if the trucks not running, but as long as its running it comes right on. what is the advantage of a faster heat up? are you trying to do cold start tuning?
e
TurboTony
I have one of the diy kits, not the tech edge, dunno if they could help or not.
Mine takes around 45 seconds once the truck is running, maybe a bit more. Just trying to speed it up a bit is all.
I saw that also, just curious what wattage of resistor I need. I like to keep the smoke in, to damn hard to round it all back up :D
My kits didn't come with any extras, what are the specs on the ones you have Jim?
Whoa Dave...
Most of that went way over my head, remeber I just a dumbassed canadian. :wink:
Thanks everyone
Tony
myclone
TurboTony said:
Whoa Dave...
Thanks everyone
Tony
Sorry :oops: :oops: Looks to me like any resistor added to R4 will need to be of the same wattage as R4. So youre gonna need 5 watt resistors IMO. You might get away with less wattage but I dunno for sure as I havent actually measured the current draw on the heater.
If I ever get around to hooking mine up and trying it I may tinker with changing the capacitor values to see if it helps. I'll post the results but it'll be a while since I cant find the plug I got off a fellow board member anywhere. :roll:
