DIY WB "backwards" post.. (part II)
myclone
Dunno whats up with the board lately but while replying the post dissappeared. WTF??? Luckily for me I have gotten in a habbit of copying whatever I am trying to submit before actually hitting the submit button.
Anyway, this is pretty well where we were at before the post decided to do its David Copperfield trick. :roll:
turbodig said:
Sounds to me like the sensor is losing heat, or voltage, or both...
Where is your voltage coming from?
We installed it temporarily connected to the positive terminal block thats on the fire wall right next to the heater box. We got a steady 13.8v there so we used a crimp on ring terminal to attach it there along with the other positive wires that were already there. When we did the final instal the WBs positive was ran over to the fuse box to a hot with key on accessory fuse.
FWIW no diff in readings were noted between the temporary and permanant positive install.
Another thing- the ground of the WB needs to go to the ECM, either
on pin B9, or on the case of it. I see too many guys hooking it elsewhere,
and that's asking for problems. SyTys have lousy grounding.
When we did the temporary install we grounded the WB to the ECM case with alligator clip leads. The permanant install moved the ground fromt the ECM case to the ECM ground wire. It was soldered/heat shrinked.
No change in readings were noted here either.
Also, if you're using the true WB code (vs. the old u-cipher-it stuff),
note what EGR% is doing. EGR % is % of raw WB voltage.... ie 50% is
2.5 volts, 100% is 5 volts. A DMM should tell you if the WB and the
ECM data match, if they don't, the patch to the binary didn't "take".
The DM and DVM readings matched give or take a milivolt or two and we were using the DM "patch" that was put out a few weeks/months ago.
O2 free air =3.98v (DVM)
O2 not enabled/warmed =2.50 (both DVM and DM)
900rpm idle with ~20spi fuel pressure =2.00 (both DVM and DM)
900rpm idle with ~60psi fuel pressure =2.45-2.50(both DVM and DM)
Im still not sure if it was just a case of two newbs trying chipping/WB tinkering for the first time plus a modified engine (larger injectors/big cam/flowing heads) or if there is actually a problem. Im leaning toward the newb thing being the biggest issue right now. What I need to do IMO is get hold of a WB sensor for myself and do some tinkering with my truck since its mostly stock to get a better feel for whats normal and whats not.
