DM-6 plx wideband hookup
IpHoOnDyou
Ok i just bought the new dm6 fancy wideband. Ive done alot of lookin around on here an i think i have my answer but im not sure... I will be removing the stock o2 sensor an running completely off the plx. For the narrow band wire am i supposed to tap into that for the plx then the other wire off the plx gets added to the ecm for wb? An then of course power an ground, im just a little unsure of how this bad boy gets hooked up. Any help guys would be awesome, thanks
Steve
abes_sy
SY #2995
Re: DM-6 plx wideband hookup
I did mine just like the diagram. i pulled the narrow band stock and inserted the simulated narrow band from the plx. and then inserted the wideband plx in the other slot.
abes_sy
SY #2995
I don't think the ecm tune can use the wideband info because the wideband uses 0-5vdc and the narrow band uses 0-1vdc.
IpHoOnDyou
So when i hook this up i will not be useing the narrow band signal anymore? Only the simmated narrow band from the plx. So from the old o2 sensor to the ecm it will not be hooked up, an the narrow band from the plx takes it's place?
abes_sy
SY #2995
Yup that's only if your removing your stock o2 and putting the wideband in its place. Some people add another bung to the down pipe and keep the stock o2 and then add the wideband. But yes you pull the pin that is in the narrowband slot which belongs to your stock o2 and put in the simulated one from the Plx device. If you haven't gotten the right pins for the ECM you can get them from Napa auto parts and I will have to get back with you on the part#
IpHoOnDyou
Oh thats ok man i have the pins for the ecu. Thanks anyway, so ok i guess my question is now..... Since the stock o2 will not be communicating with the ecu "directly" anymore. Does the wideband plx form some sort of signal for the ecm to interpret? Is that the whole point of the simmulated narrow band signal? It takes the wide band an converts it to narrow band for the ecm to read correct? Thanks again guys
Steve
