DM file needed with Ext. WG
Typhoon #1133
Anyone have a DM file with using a Ext. WG? Like the mini gate? I want to see how good they really control boost. A file with the stock turbo would be best. I just want to make sure it is worth my money before i buy one.
Thanks,
Keith
InvisiBill
I have heard that opening up the stock turbo's wastegate service port and using a modified downpipe (JS/Christian Dionne style) fixes all the stock wastegate's inadequacies. If you're thinking about upgrading your downpipe, that may be an option also. You don't have to mess with making it fit on the crossover and routing vac lines and stuff that way either, the stock system just works like it's supposed to. That's what I plan to do eventually.
Ian Turgeon
Cascading Inspiration
http://www.sytyarchives.com/test/sy2424diagnostics.zip
theres 7 diacom runs from 13.6-12.98
runs were on a hot day, ic temps consistantly in the 100's till the faster runs when I began hot lapping, getting warmer and warmer.
progate on the x-over 15lb spring, home depot regulator, and a too-low-stall TC. All runs on T1-16.
saudi res w/ no exhaust
walbro 255
afr
~98 octane
