akwilks
Mr. Keith
I have my first datamaster file after verifying everything that is in my truck. I was hoping that I can get some eyes to look at the file and generally tell me what is happening with my truck. I am running a Phil long chip on setting 2, 50lb injectors, fuel pressure set at 43 psi with vac connected, hotwired ic pump, msd ignition, 3" exhaust no cat, gn style turbo 3" downpipe w ext wg, hi flow fuel pump, 2500 stall, cold air intake with the rest pretty much stock. If anyone is interested in looking at these files I would really appreciate it. I have two files, one where I started the vehicle and allowed it to warm up. The second is doing a boost launch at 5lb or so boost and little bursts here and there. I only drove it once at wot and didnt have it there long. I'm not sure what is going on with my truck but I dont want to blow up the motor.. She does sputter at low rpms ( slowly accelerating from idle 850 to 1k). I did see about 3-4 degrees spark retard here and there with spikes up to 8 degrees. I also think that at low rpms she is running a bit rich. She definitely runs better than when I first had the motor put in. Right now there are no codes....Sorry for the long dissertation but really could use some help here....Thanks to all in advance. If you could, leave me an email address to send it and I will send it to you.....Thanks
Arn
Arn
