DM Screenshot
Goshinki
DTC Error 13 31 32 >.>
Knock Count is at 3529 from start up...
Then jumps to 3550....
DTC Errors came from the night before because it was below freezing and my truck has problems when it gets really cold >.>
Trucks not running perfect need to get a chip and get my air to fuel correct for my boost level.
Just wanted to know if from looking at this can you see any other flags?
WyoSyclone
Re: DM Screenshot
Are you doing WOT runs? A shot of that section (100% tps) may be a little more helpful. Looks like you'd already let off the throttle at this point in the run.
Re: DM Screenshot
Send your file to mednetclass@hotmail.com
Some trucks just have high knock counts durring start up. Thats normal. After you warm up just start logging over and see what you get. Dont get a chip until its running right. Get that Code cleared up also. Get a walbro fuel pump installed if you havent already and new fuel filter. What is your boost level?
Goshinki
Re: DM Screenshot
Staying at WOT makes me cut out... I need to turn down my boost...
Just installed Taylor wires and new rotor and plugs... Just wanted to make sure I wasn't getting any knock on a daily 40 minute drive to work.
I will post a run later at WOT
Flyin Ryan
hated cuz he drives fords
Re: DM Screenshot
knock is shown as "spark retard" in datamaster... I would pull the ecm b fuse for a few minutes to or the battery cables to reset the ecm so those stored codes are no longer in there.. if they come back then you know there a problem, look em up and have at it.
Re: DM Screenshot
Why do you have it tuned up past 14.7 psi? You should never try this on the stock chip and map.
Goshinki
Re: DM Screenshot
I am having problems trying to upload this file... my datamaster can open the file but if I go to the testdata folder my file isn't there even though the open file properties shows that that's where its located.
It won't even let me copy it from the datamaster open file because it states verify the item's location and try again.
How do I export this file to my desktop so I can upload it?
PS the folder doesn't having anything hidden... and when I do a search on my computer I can only find the short cut for the file...
Re: DM Screenshot
To replay the file to are getting if from somewhere. Look at the path the file is in when you open it for play back. Its just like any other file in windows. Right click and save file to desktop and send them the file.
Goshinki
Re: DM Screenshot
Got new Walbro pump and a new fuel regulator from detroit turbo.
20G Turbo
But because of my exhaust (I believe) I am running at 17.5 PSI...
Goshinki
Re: DM Screenshot
I followed that path but their is nothing in the folder... It was a copy n paste...
It wont let me move the file or even ZIP or winrar the file with out saying verify your file location.
Raist103
Re: DM Screenshot
real ? is why would you run 17.5 when you may have any knock
Flyin Ryan
Re: DM Screenshot
What chip do you have? Are you seeing any spark retard with that 17.5 psi?
If you can't find the file but you can open it within Datamaster then open it up and save it as and choose the location you want to save it to then you know where it is and can now do what you want with it
Goshinki
Re: DM Screenshot
Stock chip
From a 90% open throttle I still didn't get any Spark Retard but after a minute or so after getting off the gas my check engine light came on...
Going to reset the EMC and try WOT and see what happens.
Most likely I'll try this tomorrow.
I'll see if I can upload the 90% run... I thought it was 100% but my carpet was bundled up under the gas XD
