Do i need this adapter?
spooldup
Super Member
i just got the datamaster today. Do i need to use that beige adapter that comes with it? Can i just plug the black 9 pin in the back of the laptop and go?
just a 6
R.I.P MyClone
No!!!! That beige adapter is with the cable for a reason..............to use it.
Swede//
spooldup
Super Member
well here is my other problem them. That stupid adapter does not screw in so it keeps falling out. Also why does it have two legs sticking out of it that when u go to plug it in, it hits the damn com port!%&^%#!!!! I had to unscrew the terminals meant for holding a cables screw ends in order to plug that damn thing in.
just a 6
R.I.P MyClone
My cable came with ALDL cable attached to adapter, then it was a serial cable attached on the other side of my adapter that i plug in my laptop. Do you have the same setup?
just a 6
R.I.P MyClone
Well, go and get a serial cable between the adapter and laptop and you are set, just make sure it's NOT a null modem cable.
On 2002-01-08 22:07, 92 black typhoon wrote:
no they did not give me that.
