Is the cam stock?
how much boost was that at?
any detail as far as what it didnt like and what harmon helped out with to get it sorted out? What type dyno was this on?
The other thing i don't get it the sheer drop in power after 4400. Is this typical for these?
Tom, my other tuner and myself have all discussed those same things valve float, ignition, and the cam being to small, but haven't come up with a definite answer yet.
the cam once i remember which one we think it is i can look it up in cranes catalog and post back on here
i believe the valve srpings are stock l35's but haven't had a chance to look yet. so it's possible
not quite sure how to check ignition aside from installing a 6a box and taking it back to the dyno
EDIT but wait....i have a little tool i bought a while back that will test the amount of spark jump, and you can measure it. would that be a good starter?
http://www.oem-tools.com/products/show/25069
Was that AWD hp or was it at the crank? My truck did those same #'s with a similar turbo and dropped off at 4400 rpm as well but I had the stock cam/heads at the time.
Well took it to the track fri evening and I was so disappointed that I tore it apart Saturday. Found stock Valve springs. We have new ones ordered already but now I'm wondering about rockers. Are the stockers ok or should I go to rollers?
