do we have high impedance injectors
11secty
will the 65 lbs an hr injectors work without switching any wires and will it work with my ultimate chip
Tydriver
TurboLS6 Powa'
Yes and Yes.
As long as they are Mototronics (not 100% sure on spelling) Injectors. They are High Impediance Injectors, I will be installing them on the LS1 project.
However the calibration will more than likely be off however for any ULTIMATE CHIP setting however, I dont think there is a calibration out for the 60-65# injects.
11secty
thanks
thanks
thanks sy2932 that helped a shit load i realizes i have the old chip without the display but there going to fix that
ghettosled
SYTY SUPERSTORE
the ultimate chips are specifically calibrated for the 50# injectors. Honestly if you are maxing out 50s with the ultimate chip you are doing pretty good. I would say its time to either do your own chipping and have nolan modify the ecu for larger injectors, or look into a standalone system with built in drivers that can handle low or high imp. injectors.
