dodge stratus fan wiring help
berzerker
wookie
beginning the wiring of these fans . Will be using the Stratus factory wiring plugs with spliced in relay 's . triggered from abs main power so they come on with ignition on . main power supplied from back of alt.
Any tips or notes of which factor harness wires go to what would be helpfull . thx .
Beavis
Still plays with trucks
Re: dodge stratus fan wiring help
I'll give you a hint.
Use the white wire on the wiper motor as your "ignition" signal to control the relays. This wire is protected by the WIPER fuse. It is hot in ACCY, RUN, but not START. Electric fans will cause a voltage drop during cranking that will weaken the spark. Using the white wire, the fans will turn off in START, so you get a hotter spark, and faster cranking speed.
That is a great tip Dave. I might have to use that myself. Thank you sir.
berzerker
wookie
Update ....this work's great ! Thanks for the tip Dave !
