Does anyone use a exhaust temp?
blk00z28
Forced to by choice
I notice alot of the times when reading about turbo diesel's, they all like to have a read out on exhaust temps. How come I never see this on here with our trucks?
Does it not matter, or what?
Maxtor
Re: Does anyone use a exhaust temp?
A WBO2 is a better indicator of lean/rich IMO. An EGT gauge could be helpful during a run to keep you from melting your motor if something goes wrong, but knowing actual AFR is more useful for tuning. Your truck has both - the ability to datalog AFR and a WBO2 gauge to watch as you run.
Also, unless you are going to put an EGT in every cylinder you will only be getting a combined picture of all the cylinders. If only one cylinder has a problem or leans out you likely won't see the problem.
Most people who do an EGT put the probe about 1" outside the #1 cylinder if putting it before the turbo, or you can just put it in the DP close to the turbo (not as good). I think I even read that someone put it in the turbine housing of the turbo.
conlyn
i was actually almost convinced to buy a pyrometer for my truck, i think i might end up doing it one day... just need to find the matching autometer one.
And, it's about as useful as a trans temp or water temp gauge... if it goes into the red, stop your truck :lol:
blk00z28
Forced to by choice
Thats what I've seen alot. On the DP. I was talking to a friend at lunch and he asked this. I wasnt quite sure on how to answer him. I knew not alot of people use it. But for that reason I had no idea.
SpoolingTurbo6
I have mine post turbo. I see EGT's around 900-1,200 *F. But it's far away from the manifold port. They say (and I agree, It's best to put the right on the boss of the manifold)
You get the best reading.
93ty475
I installed mine for the Bling Bling factor, yo... :thumbsup:
around the same temps as Tyson's....
Jimmy
Banned
I got one before WB02's were out.It does help guesstimate if you are running rich or lean.Mine is in the 3 bolt to 4 bolt adapter.
SpoolingTurbo6
I went digital....I like the max/hold button...............If I remember to turn it on at the track
BigAl...
Long before wbo2's were popular (BTW egt tuning comes from the aircraft industry) egt was the only way to check tune (except ofcourse for plugs) alot of us made good power using egt's but since wbo2's became availbable egt's became obsolete! now if you have an egt sensor on each runner of the header then they are very useful because you're able to identify rich/lean cyliners. Remember you can raise/lower egt's just by changing timing. some might say egt's are as useful as a narrowband o2 sensor.
I would go as far as saying save the money you're gonna spend on the egt and buy a wbo2 sensor, you can get them as cheap as $300.
just my .02 worth.
BigAl...
Windedv6
Ty n 10s
I run one in the turbo exhaust housing...It runs 1,650 -1,700* WOT at the end of my runs. I watch my egt gauge during the end of each run and would shut down if it would pushed over 1,700*...so far it hasn't. Even though my AFR's are stable, the temps will climb a the big end of a hard pull. Lowering the afr, of course, will bring the temps down. But to maximize the tuning I run the afr up just enough to keep the egt below 1,700* at the traps. Every truck will be different on how it's AFReffects it. Depends on many varibles. The egt allows you to find a max comfort level to bench against how far you what to push your AFR. I learned this from a couple of GN guys that are much faster than any of us.
Also, the egt temps vary as to where you install it. I am comfortable with 1,700* with my setup, whereas someone else may find their comfort level at 1,400*. The exhaust housing will be hotter than the DP. As far as one in every cylinder for tuning...that would be great. To have one in each cylinder to catch a problem at WOT...good luck. By then if one cylinder went down it would already be to late.
John
92 Ty 1173
I have a Dodge with a diesel and I think the main reason you see them so much in the diesels is because a high EGT( 1200 deg) is very detromental to the engine. Besides your talking apples and oranges here. A diesel runs such a higher comprssion ratio then a gasser so that changes everything right there. There is a gauge called X-monitor which is popular in the diesel world made by BD performance. The read out is the size of a credit card and can monitor egt's,boost,trans,oil, etc. It's like $500 but it is a nice clean small unit.
