Logan
From everything I have read I am under the impression that CEL code 43 (Electronic Spark Control functions check fail or something like that) basically translates to say that I have knock. Is this correct? If not, any ideas where I should begin looking. The truck throws this code immediately when started after hooking the battery up.
I have installed a new knock sensor, with thread tape and it is not overly torqued. Double checked the pigtail to the knock sensor and it is secure. With that, I saw on another thread that the knock sensor doesn't actually function until 1800 RPM?
My timing is set, just did it last night and it is set on the right mark and the balancer has not slipped. I don't know if I'm on the right track.
Would that code appear if the ignition module in the distributor was bad or having problems?
Any help is appreciated. I am so close to being able to finish it up and drive that these last few gremlins are driving me nuts!
