Re: Does ECM respond better to WB?
ashman said:
unless your using the new $59 code, the WB data is not used.
with the hack'd $58, you'll just be able to monitor WB with DM/TP.
:werd:
My only thought is that the wideband simulated won't be as accurate as the stock narrowband in the range it's using. It's essentially "dumbing down" the signal for the ECM. If the stock has a 0-1V reference for a small area of AFR (like 14.4 to 15.0) the 0-5V reference from the LC-1 reads a greater range, so you lose a little resolution in there.
In the end I'm sure it's really no big deal at all, and it will work fine, just some thoughts.
Having the wideband will be of great use if/when the code59 gets released to the public. The closed loop from the wideband will let you spec a good AFR, and it will stay pretty close to that with the new algorithms.
