stock injector ultimates are programmed for the IC pump to run fulltime, so if you use the IC pump output as fan control....your fans will run fulltime.
The 50# programs - it was assumed (by me) that either a) the owner would have an air-air IC and not need the IC pump relay, or b) the owner was knowledgeable enough at this level to know how to hotwire their IC pump.
