does this sound normal?
Raist103
typhoon fever
ty comming soooon
Re: does this sound normal?
thats what mine sounds like. i can hear it when im sitting in the drivers seat with the windows up
Flyin Ryan
hated cuz he drives fords
sounds stock to me bro... also i think code 42 is knock sensor
did u remove the ecm b fuse for a few minutes to clear the code and see if it comes back?
Raist103
it came on after i got back from a ride i just happened to see it was on, i dont remember seeing it when i was driving. when i shut it off and turned it back on it was gone. i also here a nasty grinding noise when turning 3/4 turn. only new things on the front end are belltech sway bar and i put my z06s on.
JuStBlAzIN
Do you happen to have solid motor mounts? Check the cross-over pipe and the steering linkage.
As for the code 42. Mine has that too. I am trying to work the bugs out of it before i take it for a spin. When you set timing with out the tan wire you are at 0 right? What about when you plug the wire back in?
Raist103
brand new stock mounts.
as for the code 42 only saw it once.
i started the truck unplugged the tan wire set timing to 0 when it hits 0 it is hard to keep it there as soon as it comes close to 0 it jumps down like -15 and i have to set it at like 2-5 for it to stay in one spot. i then tighten it down and check again and then plug the wire back in. i did not check after i plugged it back in. plan to run some datamaster tomorrow just ran out of time tonight. i will double check timing tomorrow.
JuStBlAzIN
I am only asking because on my truck i set it to 0 then when plugged in it jump to +24*. Wondering if that was ok.
Raist103
ill let you know what it is tomorrow before i play with it. i will then double check it.
Deanzsyclone
Damn that's loud, maybe I forgot what stock injectors sound like but I can't believe that's what is was... but its been years since I heard stock injectors.
etriebe
Code 42 Is An Ignition Control Circuit Code And Should Always Set When You Unplug The Tan And Black Wire Id Say Your Probably Ok On The Code Issue
ViciousV6
400HP/550FTLB
It sounds a little loud to me but again we are trying to listen through a camera or phone.
The timing should be set right at 0. It shouldn't be jumping around as you are trying to set the timing, could be something wrong with dist.
Mine always stayed at 0 without even tighten bolt down, and then would tighten it, double check perfect and tighten bolt.
Maybe you should take that thing down to Toms River this weekend so i can listen for you.
Ralph
alwayscode390
pppssssshhhhhtttttttttttt
Mine are loud too... I can post a vid if you want. Everyone tells me its weird, but I know its normal for us. In my vid you can hear them over the fan WHAILING (cant wait for my e-fan swap) ---
Raist103
ill be in va but maybe next weekend. plus i have to find what is grinding so bad when i turn before i make a long trip.
Ralph
alwayscode390
Sounds like you have too wide of front wheels? Mine rub in SUPER TIGHT turns too ---
Raist103
no it is not rubbing it is metal grinding. i had these on my ty for years and i heard them rub full turn but this is ugly sounding.
Flyin Ryan
mine tick like that and I just use it as leverage when racing someone.... see here it, it's going to blow the hell up so now how about we put more money on this race :)
Raist103
well went and checked the timing. looking down from the front of the car it is almost straight up no where near the pointer. unplugged the tan wire and it is damn close to 0 almost 0-2. i am still getting code 42 at idle before i take it out and drive it. found my boost gauge is not working , but my fuel gauge is and i have almost 50base with line off. it does climb up as boost comes up so fuel is fine. i will run it with datamaster if i get some time tomorrow. also found the upper rad neck is leaking. time to change out to a 160stat and new gasket.
ViciousV6
400HP/550FTLB
I'm Sure to the rim is grinding on the Lower A-Arm which is same problem i had with ZR-1, so i had to do a little grinding on the a-Arm and all Fixed.
Ralph
