Doing Full Engine Tune-Up: Ordering Parts
v6stanger
My Sy has almost 92k miles and its finally coming out of my garage to become a daily driver for spring/summer which is approaching pretty fast.
I want to get the truck back to running where its supposed too. It doesnt feel like a 13 sec truck right now. It sat for about 2 years in a garage before I purchased it.
My starter normally takes a few clicks of the key to crank over so I will be doing the "purple wire" fix and a new starter along with the tune-up.
What starters do you guys recommend that are a direct bolt-on? I saw some guys mentioned using starters from different GM vehicles but I'd like to be sure before ordering something that won't work.
Here is what I've compiled so far:
1. Racetronix Fuel Pump Harness w/ Walbro 255 Pump
2. RPM Plug Wires
3. MSD Hi-Output Coil from RPM
4. RPM AFPR
I'm deciding on plugs now. I see RPM recommends UR5's for stock tune-ups but most guys on here seem to like the UR6's. What am I better off going with for a stock motor?
Anything else you guys recommend?
willyson
trollin'
Re: Doing Full Engine Tune-Up: Ordering Parts
when your doing the starter, i would put some heat shield on the starter/spark plug boot protectors around the wire connections to the starter. Its particularly close to the dp and gets pretty hot around there. Double check your grounds on the starter while your down there - it might save you some headaches later.
here are some part#s from sytyauthority (couldnt find msd)
Accel #8133
Conrad Brass: DR2012G - no longer avail - (duralast)
Cap: GM #10477182
Rotor: GM #10497452
Standard: cap DR323X rotor DR460X
Wells Pro Gold Prem: #DR2012G
make sure you get one with brass
v6stanger
Found my part #'s
MSD Coil- MSD 8226
MSD Cap/Rotor- MSD 8430
Are you guys buying your heat shield in bulk or do they have specific stuff for wrapping starters and other such parts?
EDIT: Answered my own question. Summit has heat wrap. Any idea if i need the 22 or 24 inch starter wrap?
Should I use heat shield on the plug wires as well?
willyson
trollin'
You should be okay as long as the wires dont rest on the DP, but you might want to put the spark plug boots there also, which would be their original intended purpose. good wires handle a fair amount of heat pretty well
Flyin Ryan
hated cuz he drives fords
AC CR42TS plugs are the norm.. many including my self go with the NGK UR5's for a slightly colder plug to help with KR and improve idle.. I didn't go with the UR6's because i've read it's not needed or recommended for stock or lightly modded trucks (don't remember where it was a thread from years ago) but im sure if you do a search it'll help you make your decision.
Starter.. alot of guys when changing out the starter go with a mini style to save weight and to help make the install that much easier. Here's a post about it with part number http://www.syty.net/forums/showpost.php?p=748&postcount=2
also I would without a doubt heat wrap the starter and positive wires to it as good as possible and clean your ground so you don't have to ever worry about jerking with it again.. also buy some plug protectors for your spark plug wires which will help them last longer because that turbo and downpipe put off alot of heat.
v6stanger
After doing some searching around I'll take your advice and go with the UR5's since the truck isnt getting any major upgrades anytime soon.
I havent had any luck with Jegs and the CVR starter. I did find one made by GM Performance and one by Proform. Stock blocks will accept staggered or inline bolt pattern and 168 tooth flywheel?
Six-is-Enough
Use to do a little Boost
You got your #'s mixed up a little.NGK UR5 is the stock heat range plug. NGK UR6 are 1 step colder.
The japanese plug manufactors # thiers diffrent than U.S.. NGK and Denso the larger the heat range #, the colder the plug.
For the U.S. manufactors it is the opposite. Smaller # =colder plug.
X2 on the starter heat wrap. I did this on my truck and it has been great.
2. RPM Plug Wires
4. RPM AFPR
Brass Cap & Rotor.
I would skip the high out MSD col, I have heard it just reduces the life of the cap/rotor even more. I would also skip the Racetronix Fuel Pump harness, its not needed for a mostly stock truck, this isn't a Buick GN that has voltage problems at the fuel pump.
v6stanger
I'm going to change the fuel pump anyway because of the mileage so while its apart I figured the harness won't hurt and it'll be there for the future when I decide to do some upgrades.
I guess I can just go with a stock replacement coil from GM then if the MSD just wears the parts out faster.
