downpipe removal
Slyclone
Well-known member
Hi anyone got any good tips on removing the downpipe from the cat. the connection was a clamp type and there is a slip fit. I have tried PB to try and loosen/free. Not looking to Saw it off as the component is still good. Tried some heat. Also tried a chisel and hammer. Its tight under there. I guess removing the trans cross member is the easiest?
Black Knight
I Glow Therefore I am
Re: downpipe removal
Heat and more heat.
I had one that I was never able to get apart so I had to cut it off, but soaking it with some kind of penetrating oil and letting it sit should help as well. If you're going heat it after that just be careful of it catching fire.
leadfoot
Parallel to the the outer pipe (at slip fit) -slit in two places 180 degrees apart. Soak slit with liquid wrench or PB blaster or whatever.
Slyclone
Well-known member
Did not make any advancements at all today. things been a real MFer. I layed out a air hammer and tried to make a couple little hits. Nothing. Also staged my grinder and thought about running a quick slice but its so confined under there. Im trying to run 3 inch back off turbo and not sure what to even do with the cat. That will probably be going anyway.
Black Knight
If you're planning on dumping the cat anyway, cut the pipe right next the cat inlet (as to avoid hitting the d/p), scrap the cat (think I got $75 - $100 for the last one), sell the d/p, install all new go fast shiz!
MikeRenz
not stock
have you unbolted it from the turbo and that stupid firewall/tranny bolt? I usually knock them into the cat a little so i can twist the downpipe/flange away from the turbo...and then knock it out.
That pesky hiding bolt stumped me for a while the last time i did it and was rusted tight so i just sawzalled off the tab.
Slyclone
Well-known member
annihilated my finger today on some heat shield looking $hit up under there. Right when it was about to get it off, I had to pack it in and get bandages. So close.
I tried many things today, I cut a slit in pipe. Relif cut if you will. I pry some of material back. Sprayed with PB. I was back and fourth with bolting the turbo up, and the dp to get a secure hold on them, and try to hammer @ the lip of cat to seperate No luck. Pipe was twisting and what not, But not advancing forward or showing me anything. I looked in manual. Service suplement. Maby I am over analizing thing here. THe end looks hatched in books. Is the pipe have Knurls on end? Like I said I was close. almost severed my finger off as I twisted pipe and it went a bit further and than got stuck against something sharp? maby trans pan edges or the heat shield.
Maby A fresh start will get it off. I have no clue. Truck really isnt going to be going anywhere any time soon
The trans bracket didnt look like a real problem/ Which way do we take pipe out anyway from top or remove from bottom?
