Drac box question
skolman91
The drac white box on the pass side has nothing to do with the starter circuit does it only speedo right? I see a yellow wire running to it and thought id ask
Also seperate but anybody have a diagram pinout of the center console harness??
Re: Drac box question
Starter circuit does not go thru the DRAC at all. It is a multiplier/divider for the speed signal from trans.
Aeroking
e.i.
IIRC yellow wire goes to cruise control. Blue wire goes to dashboard tach. Purple and Gray are from speed sensor in transfer case. But that's from memory.
skolman91
Thank you gentleman thats very helpful, but i was looking for the wiring harness connector that runs to the shifter that has the back up lights, neutral saftey, think their is also some lights for the shifter etc, for a sy so i have no aux outputs or remote unlock.
