I have some pretty strong evidence against blocks after watching them come apart on plenty of trucks. They place HEAVY torsional loads on the leaf springs just before and aft of the blocks. Any mechanical engineer would agree the leverage extracted by the blocks on the springs under a boosted launch is intense. Working in the off road industry I saw plenty of axle shaft, housing, and leaf spring breaks on trucks running blocks. Though the added weight from the large tires on these trucks didn't help, all failures happened under acceleration. I'm sure our trucks place similar loads under acceleration, substituting horse power for tire weight. You can go around it with traction bars, but bars on blocks is pointless. I'd recommend a softish mono or dual leaf setup with caltracs and a panhard rod. The soft spring will improve weight transfer on launch as well as ride and the traction bars will keep the axle from wrapping up and breaking those springs. Stock axle wrap is controlled by a stiff multi-leaf spring getting the job done while sacrificing ride and handling for simplicity.
I don't know jack about this stuff compared to the folks I used to work with/around. E-mail me if you want to contact any of them, but this is the same kind of stuff seen on Al Dunstan's rear kit. Locating arms and a panhard rod locate the axle and eliminate wrap letting the suspension (coil overs b/c leaf springs aren't needed for axle locating anymore) carry the proper spring and damping rates for their job instead of worrying about axle movement. There's plenty of people running blocks with no problem, They just raise the hairs on the back of my neck. You wanna go fast or look fast?
Jeremy
