Re: Dropped a nut into the block
Are you sure its brass and doesn't just look like brass?
BTW Your suppose to drop your nut into a box not a block
It's a new alt from Autozone. It's the nut that came with it - anyone know if they're magnetic? It has a collar on it.
Gonna empty my nuts this weekend for sure :tup:
As stated above:
Do it in this order.
1) Put the front of the truck only on jack stands for a good angle for the nut to slide to the back of the pan. Drain the oil and try to flush the nut into the sump. You can use clean trans fluid(light weight and easy flowing) or a w5 weight oil. Let it flow out the sump drain into a clean pan so you can reuse it to keep flushing. Pour it in the front opening of the lifter valley or into the front valley wall holes that go to the timing chain area which finds it way to the front of the pan. Lightly tapping on the bottom of the pan may help move it back. To try to bring it to the drain hole by sliding a stong magnet over the bottom of the pan towards the drain as the nut inside should follow the magnet if it is steel. If it is truly brass (non magnetic) and not just a bass looking plated nut it should be lighter and may flow out easier than a steel one.
2) If it doesn't flush the first couple of times it may not be in the pan. Visibily check to see if it is sitting around the cam/lifter area. If not seen there slowly roll the motor by hand to the pan as should fall/roll off the rod crank area if it is sitting there. Reflush.
3) If flushing doesn't work think about dropping the pan instead of pulling the motor. Many of us have dropped the pan vs pulling the motor.
Sorry that this happened. Many have learn the hard way so you are not alone in droping something into the motor. I personally put duct tape over the distributor hole as soon as I take it one out. If removing the intake, always put a clean lint free towel over the lifter valley as soon as an intake is off.
John
Thanks John, that's what I'll be doing. In terms of dropping the pan, not the motor, I thought I had to remove the diff/motor to get the pan off. It's not in front of me so I can't visualise it. Is that correct?
I have a new gasket so if it comes to that, I'll be ok.
I'm trying to avoid hours of work to pull things off but it may be necessary in the end
I guess I am concerned that the nut bounced into the crankcase and is resting on the top side of the crank and could get fouled if the engine spun. I wish I had one to hand to look.
Annoyingly, I normally plug all of the holes. I won't make that mistake again!
Stay tuned - Saturday morning is when I'll be wrenching for 4 days straight I hope!
Thanks for everyone's input
