Drove the Sy tonight!!!
Injected1
Well guys got to take the first spin in the Sy tonight. The timing problem you ask? The Edelbrock double roller had an arrow and a dot on the crank sprocket, I couldn't see the dot at 4 am after 18 hrs of work and working on the truck so I lined up the aroow instead of the dot. The timing was off about 4 teeth! Once we fixed that it all fell into place like a fairy tale. TDC- harmonic balancer @ 0 and dist, right at #1. It was beautiful. It's still stock except for the 20g but it is a rocket. I am having 2 slight problrms though.
1. I installed the Rpm turbo to intercooler hard pipe and the throttle body to intercooler hose with 2 clamps keeps blowing off. Do I need a BOV between the turbo and intercooler?
2. When I did a 10psi launch I heard a harsh grinding clicking noise from the left side underneath the truck. I brought it back to the house and felt the axles and the left flange off the differential had alot of slop it it and the right one had none. Does the whole diff. need to be replaced? Is it easier to fix or replace?
I would also like to thank everyone on this site for all the help and past posts. I will be donating soon to keep SYTY alive. I have never done a complete motor swap before and I was able to pull my Ty motor and install it in my Sy with the help of Syty. Special thanks to Mike Hood, Jwaller, and S_blazin.
Lastly I have a 3 bar map and access to an AFPR, and brand new 42.5# injectors that came with the truck. Also with the truck came a brand new STG 50# radar chip Would it be easier for me to have a chip burnt for that setup or trade the new 42.5 for some used 50#'s? Anyone want to trade or burn me a chip? Let me know the cost and what i need to do now. Thanks again everyone.
Special thanks to the love of my life for supporting me and believing in me through it all. I LOVE YOU KRISTIN!!!!!
P.S. "Syonora" 600hp build is coming soon................
Nick
Aeroking
e.i.
Re: Drove the Sy tonight!!!
do you have all 3 of the intercooler support brackets installed? are the clamps on the intercooler-to-throttle body tight over the intercooler mouth ridge.
i'd trade the 42.5# for 50#s. That way a custom tune isnt needed. :2cents:
