Re: Dry Sump 101?
Madekatsu said:
I've been considering for a couple of reasons. The first was that the truck is being used for drag racing, and I want to cover all of my bases. The second reason, was to possibly avoid, or lessen the amount of metal I have to cut out of the crossmember to make the oilpan fit. However, looking at Winded V6's pictures, the pump system (?) appears to take the place of the a/c, which is also another thing I want to avoid, since I'd have to notch out the side frame. I haven't been able to find a picture of a dry sump system in a Corvette or F-Body yet though, and the placements might be different. Right now, I'm just not sure, and I'm constantly exploring possibilities because the engine is going to get done last.. and hopefully only get done once... :lol:
I keep forgetting you're working on a GT, not a Sy or Ty.....
Most of the 2wd swaps I've seen do involve cutting the crossmember, but only because its easier than modifying the oilpan (welding steel vs alum).
For my Bravada, I took a completely different route. I knew that modifying a cast alum pan to clear the front diff was going to be difficult if not completely impossible, I just built a new pan. A couple of pieces of CRS flat bar (I think I used 3/8" x 2"), a 2' x 4' piece of 16 ga steel, 4.5" grinder, jigsaw, MIG, Drillpress, and some tin snips were all that was really needed. I did end up using a bandsaw, since I have one at work, but could have gotten away without it. It wasn't all that hard. I consider myself a decent fabricator, but I am by no means an expert. It wasn't the hardest part of the LSx swap into my Bravada.
Most drag vehicles I've seen use wet sumps. For acceleration in one direction only, you can make a wet sump work pretty decent. Road courses are where wet sumps run the biggest risk of letting you down due to acceleration in 4 directions (drag + braking + left corner + right corner).
Cost wise, the dry sump setup is pricey. I'd expect to spend $2000 to $5000+ (depending upon if you use any used equipment or not, but all the hoses and fittings, and such really add up).
The internal dry sump used on the LS7 would certainly be worth looking at. Would require a new crank, but if you're building a LSx motor from scratch, you may be doing that anyway.
And lastly, there's things you can do to make a wet sump more reliable. Like an Accusump (I think thats what its called). Basically its a cylinder used to store oil under pressure. The oil pump pushes it in under pressure and it returns oil to the motor in the event that the oil pump isn't supplying oil.
One more thing to mention. There's alot of discussion on LS1tech.com about LSx's into S10's (in the Conversions & Hybrids Forum). You might check there (if you haven't already) for some more info on oilpan / crossmember interference.
'JustDreamin'
