DTC code number
Boostin 92
Re: DTC code number
Dwayne:
42 is set when the tan/blk wire is disconnected to set the timing. If the code is not cleared by pulling ECMB fuse for 10 seconds, it will clear on its own after 50 ignition cycles.
33 is MAP Sensor Low Vacuum indicated. Very often it's a split or disconnected hose from the manifold to the MAP. Or an IAC or EGR problem that causes low idle speed with low vacuum. Conditions that will set 33 usually cause black-smoke rich exhaust. But check the MAP signal hose very carefully.
thanks Dave
