jwaller said:it was an atr setup with a boost pressure sensor and an extra relay for the second pump. 1 255 does a good job. IMO duals are not needed.
the only fancy part is the Y piece that connects the 2 pumps to the 1 line. if you are going to stage them like atr did the Y also has to have a 1 way valve.
you could always just run them both at the same time but you run the risk of issues if you tune it that way and 1 of them dies.
