Dying your carpet
Defiant
Is your carpet fading, or discolored?
Here is a simple solution that will make your carpet amazing!
What you will need:
1. Rit dye
2. A 10 Gallon Tote
3. Time
You can find Rit dye at Wal-Mart or any local craft store.
The first thing you will need to do is pull the carpet out of the car, so you are able to clean it. I recommend cleaning it with a pressure washer. Pressure wash the carpet until the water that comes off the carpet is clear and clean.
img.php
I wanted my carpet to be a very dark black, so I purchased 6 bottles of Rit Dye. The bottles are suppose to dye 2lbs of fabric or about 3 yards. The dye also comes in a cardboard box in powder form, and only dyes 1lb of fabric or about 1.5 yards. There is about a dollar difference between the two.
Put the dye into the tote and add water, but do not fill it over halfway at first. You will need to fold the carpet and place it in the tote, then fill up the tote the rest of the way.Get a few heavy rocks or something you can weigh the carpet down, because it will want to float to the top. If you want you can put the lid on to keep crap out.
I would recommend letting the carpet sit for a few hours. The longer the better!!
After a few hours, pull the carpet out of the dye and unfold it to let it dry. If you do not let it dry completely, dye can and will rub off on your feet and/or hands.
Before:
img.php
After:
img.php
*This is my writeup from Galantvr4.org*
