Dyno numbers today...
XIXI
Re: Dyno numbers today...
Is that your setup, I am trying to figure out how to get into the mid to low 10's and I do not want to spend money on something now and later buy the part that I really need for my goal.
New Years Resolutions are the best.
low to mid 10's before the end of the year.
Your internals, can they support around 550hp?
Trying to find the right setup.
Please Advise
S/F
Syclone#2960
What ever it takes!!
The best I could muster for the night was my first run on 17 psi 11.3 @118.
Then I turned up the boost 2 psi and over launched to a 11.4 @ 120.
I need to dial in my suspension if I plan on getting into the tens.
Syclone#2960 said:
What would the HP at the motor be +15%?
Was it a 2wd dyno? Typically 2wd 700r4 (F-body, Corvette etc) are around ~18% loss. I have heard ~25% for the AWD.
With the front propshaft removed, I personally think their will be an additional small loss through the T-case spinning even though its not spinning the the front wheels. If I had ot guess Its probably around 1% though.
Congrats on the good numbers :tup:
blk00z28
Forced to by choice
Nice numbers! Almost even hp and tq!
Question though, shouldnt you be making more tq then that? (I dont know, just assuming..)
Syclone#2960
Please Advise
S/F
Give me some info on your truck as far as Mileage and mods...
Syclone#2960
The dyno was a 2wd w/ the prop removed...the tech disconnected the shift cable before the run. Is this normal???
Syclone#2960 said:
The TV cable.:oops:
WTF would they do that for? The only reason I could see is if they want to keep it from downshifting but that controls tranny oil pressure and is not something I would ever knowingly do :rant: . Years ago I was having problem with a transmission that had high shift points so per a bad recommendation I disconnected TV cable, they tranny went south really quick.
