E85 Fuel system questions
AppleTY
I am getting close to putting my new engine back in my Ty, but before I do I am seriously considering switching the fuel to E85. My goal is to get around 450hp.
Since I am going to have to buy bigger injectors, alky, wb02, chipping tools and retune the new engine anyways, seems like kind of a waste to do it twice.
My big concern is that I have to pass visual CA smog inspection.
Fuel Lines are still the factory ones. They seam to be in good shape. How much HP can the stock lines handle on E85? What can I replace them with that doesn't look like a race car?
How much HP can the stock fuel rail handle on E85? Is there anything out there that would be better, that wouldn't look like a race car?
Thanks in advance
grnty3377
Re: E85 Fuel system questions
braided fuel lines shouldn't knock you down from inspection. But I would go with billet fuel rails. Rpm sells them for our trucks but if they are too expensive I'm sure you could get ones cheaper
you have to change the fuel filter and line because the alcohol will destroy your rubber hose you need one with Teflon in side .so it can last. bigger injectors AND MORE FUEL PUMP but you don't need alky do to the gas being colder and more octane, you can save there . for 450 the stock rail will work .now passing inspection don't know I live in Florida no inspection here.
MotoCam360
One thing to keep in mind is that our E85 package uses the stock ecu housing and bulk head connectors, so CA smog won't be able to tell you're running an aftermarket ecu......fyi
One other thing to note: We use the EGR harness connector to power our E85 sensor, so you would want to make sure that's not installed when you go through inspection
AppleTY
RPM also has a braided fuel line kit, but it just goes back to the transfercase fittings. Would that be sufficient, or do I need to go all the way back to the tank?
For the pump, what kind should I get? I just put a brand new tank and pump in there. I saw one post about the Walbro F90000267, but others seem to be running the Deatschwerks.
AppleTY
I am counting on it. My EGR will be on the truck for inspections, but it won't do anything due to the vortec heads. Pretty unlikely that they will op-test it.
