e85 peeps come on in....
sharkbait
so ive been reading up on e85....and meth injection. ive readhttp://www.injectordynamics.com/AlcoholArticle.html and read all the e85 threads example
I have been running E85 for a few years, and have seen it fluctuate only from 76 to 85 in my area. In the late spring through fall it is always E83 -86. I have two stations within a mile and another about 2.5 miles from my house. They are all very consistent. If you tune while it is at E83-85 then if it drops lower the tune will be fatter. E85 is hard to detonate and I serious doubt that a solid tune on e85 will cause any issues if the ethanol content drops into 77-79 other than you will be a touch fat.
Quote:
Referring to "ASTM D5798-11 Standard Specification for Ethanol Fuel Blends for Flexible-Fuel Automotive Spark-Ignition Engines" we see that the 85 in E85 signifies a maximum ethanol content of 85% with the remainder being "unleaded gasoline, gasoline blendstocks for oxygenate blending (BOB), natural gasoline, or other hydrocarbons in the gasoline boiling range.
Quote:
Clear enough. 85% Ethanol and 15% WTF-ever, right?
Not exactly.
The 85 percent doesn't refer to pure ethanol, but to denatured fuel ethanol which already contains 2% gasoline to make it "unsuitable for beverage use under a forumla approved by a regulatory agency to prevent the imposition of beverage alcohol tax."
The real meaning of that bit of lawyer-speak horseshit is that E85 has a maximum ethanol content of 83%.
While I am sure that this varies somewhat around the country, I spoke with my local supplier as two of the stations are supplied by the same company. The tankers carry 87 octane, 93 octane and 98% ethanol. They blend what they need when they pump it. The mix of 87 and 93 octane blend into 89 octane and the 87 and ethanol blend into E77, E82, E85 depending upon the season. In late spring through fall it is cut to E85. It is not cut to E83 as quoted in the article. I check it every time I fill. Obviously they can cut it correctly.
Quote:
To be more specific, let's consider how this variation in ethanol content affects the two critical parameters of the fuel (Stoichiometric Air Fuel Ratio and Octane Rating) using the extremes of 83% ethanol, and 51% ethanol.
Quote:
1. Stoichiometric Air Fuel Ratio - Pure ethanol has a stoichiometric air fuel ratio of 9.003. The stoichiometric air fuel ratio of gasoline ranges from approximately 14.5 to 15.0 but is generally considered to be 14.7. Accordingly, the stoichiometric air fuel ratio of a mix of 85% ethanol and 15% gasoline is 9.972:1, while the ratio for a mix of 51% ethanol, 49% gasoline is 12.15:1. Based on these numbers, if we tuned our engine to a lambda value of .85 in the middle of winter, we could expect a lambda value of 1.036 when we switch to our summer mix.
Seem extreme?
It is!
I did say specific, so let's include the density of the two fuels to make our numbers more accurate. Performing the same calculation, but accounting for ethanols high specific gravity of .79, and using a value of .72 for gasoline, we get a summer mix lambda of 1.006. Not quite as extreme, but still off in left field, and likely to rattle itself to death, or turn a piston into swiss cheese.
Fortunately the summer mix will have better detonation resistance, and better cylinder cooling due to its higher ethanol content, but if the tune was anywhere near optimized before, it sure isn't now.
He is using E51 against E85 which makes a big comparison difference. It is would not be nearly a problem when comparing with E77 which is the real comparison. It may be true that they can go as low as E51, but until I see actually it happen during our spring, summer and fall months I am not getting “rattled” by it. Yea, if you tune your motor in the winter, you will be lean out on that tune come summer. Why would we be tuning our HP motors in the winter? If we have our best tune in the summer then we would be rich come late fall and winter, which would not hurt us other than shitty performance. I don’t really appreciate the scare tactics.
The injector rust thing is also not totally fair. It is true that if you let ethanol set open to the air for long periods of time it will pick up moisture, but it’s nothing like what methanol/alcohol will do. We have a closed fuel system in our trucks (unless it's modified with an open vent fuel cell setup), which closes off our system to the open air. Unless we are in hot to cold to hot temps on a regular basis we don’t even get much condensation in our tanks. I leave my E85 in my tank all winter and never have had any issues. When I run my pump it circulates the fuel through the lines and I can see the ethanol content on my gauge. It doesn’t change fall to spring while the truck is in storage.
If you are thinking about running E85, don’t let everything negative said about it scare you away. Some people think they want to help educate everyone with “applied” scientific knowledge. Heck, we would have stopped drinking water if we actually read about all the scientific knowledge that could be written as to why it could be bad for us and we should never be drinking the likes of deadly Mountain Dew!
Here is the deal. Don’t be afraid to use E85 if you have it readily available. Test it for percentage of content and adjust accordingly. A few points off of full E85 will not make a difference on most builds and daily driving habits. If you are running in the 600hp range and below pump E85 will be all you will need even if it is down to E80. If you are pushing into the higher hp builds and racing on the edge then use E85 from a reputable racing fuel supplier (Cutting ethanol with 87 octane is the best as 87 octane can light the ethanol faster than cutting with 93 octane. Most racing fuel companies no longer sell racing E85 cut with higher octane for that reason). E98 can have it's advantages especially on a hot day at the track, if tuned for it.
Keep all E85 containers closed when stored and if you want to be on the cautious side, run your truck once a month in the winter. My garage is heated to 55-60 degrees during the winter and I don’t see any changes with the E85 in my tank from fall to spring.
Don't be afraid to use E85. It may not be magical, but it's not voodoo either. It is just another fuel.
John
(thanks windedv6) and i think i want to try running e85 and tuning it myself. i have the obvious questions like "do i have enough injector"....."is my pump big enough"....."what if e85 isn't available when im running low and away from home"....etc
a snapshot of my build
PTE74
internal wg
new style 83injectors
all AN/braided -8/-6
stock rails
afpr
plastic fuel cell
external pump (have to look up the gph)
3dp
renz upper
a2a
forged internals
cometics
202/160valves
stock manifolds
accell ignition
plx wbo2
syty ecm
code59
1. so, 9afr is stoich for e85? my plx only goes to 10...
2. how can i figure if my 83s are enough?i don't want to max out my DC on the injectors.
2a. how much can idle fp help the injector keep up?
3. how can i figure if my pump is enough?
4. will it even run with the e85 on my 94 octane tune? or do i just add fuel to my closed throttle right away? before i even start the truck?
5. do i add fuel to ALL table cells just so i dont lean out trying to drive around the block for the first time with e85 in the tank?
6. a "junk yard" flex fuel sensor wont do me any good with code59, correct? guys that are using it have fast or other aftermarket ecms?
now be easy on me. i know we have sooo many guys that are happy with their meth kits. and they are going fast for sure. and the e85 guys think its the best thing since sliced bread. but for ME, id like to tune for e85 and not have to fill a bottle in the engine compartment, add more equipment, plumbing, fail safes, low level gauge etc.
so please step in, give your opinions on e85.
thanks,
domenick
Sportmachines
Re: e85 peeps come on in....
Dom,
I've seen fantastic results with E85 on a number of different cars. Just have done as much with it as we had hoped to this point, but will soon, hopefully. I prefer the e85 vs alky because of all the same things you listed.
As an overview to answer a bunch of your questions. Rule of thumb is that you'll need about 30% more fueling on e85 vs gasoline. You're pump should support it now problem. The running, you'll need to add around 30% to the values to get it running then fine tune from there. Injectors, whats your duty cycle now, add 30%. This should get you started. Then fine tune from there. HTH
sharkbait
I know about the 30% increase in fueling,but i didnt think of adding 30% to my current dc to see where id be. Good thinking. Only issue would be im nowhere near tuned. Just got it running pretty good. Still have conservative timming table etc. im up ti 220 miles on the motor. And currently have the wg at 10ish psi.
jeepruby04
I don't know alot about this but i do know you can get it to run on a stock-ish tune. I was able to get a Ty to run on an Ultimate chip and E85. It was just a matter of setting the fuel pressure with the injectors to get a dc that was close to "normal" levels at idle. By no means was it right by any standards but it should give you a starting point to determine the injector size you need.
sharkbait
i think im gonna go with just adding 30% more fuel to my closed throttle and cruz table. id love to hear from guys already running e85, but noone has check in yet.
Windedv6
Ty n 10s
thanks,
domenick
PTE74
A large turbo for the rest of your fuel delivery setup if you are going to run e-85. If you limit you boost to around 20# you should be ok.
internal wg
Ok
Small for you turbo on e-85. If you limit you boost to around 20# you should be ok.
stock rails
Be best if you had parallel rails fed by a -10 line from the tank. If you limit you boost to around 20# you should be ok
Afpr
Ok
plastic fuel cell
Ok
Make and Model?
3dp
Ok
renz upper
Renz who???
a2a
Good choice
forged internals
Always a good choice
Cometics
Good Choice
202/160valves
Which heads?
stock manifolds
Ok on your setup if you run this turbo in the 20# range. The turbo would take more flow if you were setup to run in the upper 20s on boost. (your block probably wouldn’t though)
accell ignition
Ok
plx wbo2
Ok
syty ecm
Ok
code59
Ok
E-85 stoich is 9.67…see table below.
Set up your current Gas AFRs to correspond to e-85 AFRs in the table…
(Stay out of the RED.)
Lambda E85 Gas
0.650 6.344 9.555
0.660 6.442 9.702
0.670 6.539 9.849
0.680 6.637 9.996
0.690 6.734 10.143
0.700 6.832 10.290
0.710 6.930 10.437
0.720 7.027 10.584
0.730 7.125 10.731 @ Max Power Multi Turbo
0.740 7.222 10.878
0.750 7.320 11.025 @ Supercharged/Turbo
0.760 7.418 11.172
0.770 7.515 11.319 @ Max Power NA
0.780 7.613 11.466
0.790 7.710 11.613
0.800 7.808 11.760 @ Consistant Race
0.810 7.906 11.907
0.820 8.003 12.054
0.830 8.101 12.201
0.840 8.198 12.348 @ Part throttle RACE
0.850 8.296 12.495
0.860 8.394 12.642
0.870 8.491 12.789
0.880 8.589 12.936
0.890 8.686 13.083
0.900 8.784 13.230
0.910 8.882 13.377 @ Part throttle STREET (economy)
0.920 8.979 13.524
0.930 9.077 13.671
0.940 9.174 13.818 @ idle depending on what your setup likes
0.950 9.272 13.965 @ idle depending on what your setup likes
0.960 9.370 14.112 @ idle depending on what your setup likes
0.970 9.467 14.259 @ idle depending on what your setup likes
0.980 9.565 14.406
0.990 9.662 14.553
1.000 9.760 14.700
1.010 9.858 14.847
1.020 9.955 14.994
2. how can i figure if my 83s are enough? i don't want to max out my DC on the injectors.
It will depend on how much boost you are going to run. You will probably get close to max at around 20# boost. 96 s would be better, but if you want to boost into the mid to upper 20s then 120 or 160 will be needed. At that point you will need big pump, lines, and better rail setup.
3. how much can idle fp help the injector keep up?
It will depend on the pump. If you run to much base pressure and the regulator adds 20 lbs more pressure when you are at 20# boost, your pump may not be able to keep up with both pressure and volume.
4. how can i figure if my pump is enough?
Make and Model?
5. will it even run with the e85 on my 94 octane tune? No or do i just add fuel to my closed throttle right away? before i even start the truck?
You will be all over the place on the tune if you just randomly add fuel.
6. do i add fuel to ALL table cells just so i dont lean out trying to drive around the block for the first time with e85 in the tank?
See Table…change all the gas AFRs to the E-85 AFRs. By doing this you are basically changing the fuel constant across the board.
7. a "junk yard" flex fuel sensor wont do me any good with code59, correct? guys that are using it have fast or other aftermarket ecms?
That’s correct as far as I know. I have not played with cade 59
FWIW…Here is my take on your setup. You have a larger turbo than you really need to max out a stock block capability and keep some reliability. I am assuming you have the compression ratio in the 8.5:1 range. If you keep the 74mm limited to the 20# boost range you should be fine. Your fuel delivery system is going to be too small for much over that. A smaller turbo would be a little more street friendly to play around with but the 74mmm is better at the track depending on which exhaust housing you are using. I would just keep everything you have and tune to the boost level that your fuel system can deliver. I am guessing it to be around 20-22# max. It is also going to give you about as much HP as you will want on the stock block.
Windedv6
Ty n 10s
Adding 30% more fuel to your idle table and low rpm tables will only get you messed up with the rest of your tables. The same with just adding more fuel pressure. it will be better to rewrite AFR table to the corresponding e-85 constant.
John
sharkbait
Excellent! On my cell, hard to read, but excellent info. Ty john
sharkbait
just got home from long weekend in PA with the family. great info john, and thanks alot. im gonna get the pump info and see what LPH and psi it is. its a physically large sized pump, so im hoping it will offer enough volume for the e85. it also seems that the stock fuel rails will also limit me. might want to upgrade to a straight rail set up and ditch the stocker/syty specific afpr.
i do understand that i will naturally have limitations on the stock block and crank. its a street truck, so im not looking to keep it on the ragged edge of 1/4mile performance. 20psi should be more than enough for the street. im going to look at my code59 tune some more. play with it with the gas i have now and have been using. just so i can learn as much as i can about tuning my truck. practice makes perfect...right? lol
anyway, anyone else have anything to add about e85, please put your two cents in.
sharkbait
fyi, the pump is a external mounted summit racing pump 450 lbs./hr.
Maximum Pressure (psi) 65 psi.
i couldn't find anything saying how many LPHR or GPHR. any thoughts?
Divide lbs/hr by 6 to get gph
450/6=75 gph
3.78541178 liters in a gallon so 75 x 3.78541178 = 283.9 lph
sharkbait
Oops. To early in the morning. your right. I might wanna upgrade for good measure.
