Eagle rod bolt stretch spec.
4C FED
Absolutum Dominium
I started assembling the bottom end yesterday then ran into a snag. I can't find my sheet for the rod bolt stretch spec.
There used to be a site online that had the sheet & it is gone.
There is one post on here from TurboTony & it says "measure the stretch of the rod bolt, .006 if memory serves".
I want to make sure that is correct before I proceed.
Can someone check their spec. sheet & post up the number.
Secondly, would it be worth it to upgrade to the ARP 2000 series bolts?
Thanks.
4C FED
Absolutum Dominium
Re: Eagle rod bolt stretch spec.
I emailed Eagle and this is what I got back. "Those should be stretched to about .006"."
To about .006"? WTF? It would have been nice to have the tolerance included.:rant:
Guess I'll try a good ol' fashion phone call for a change.
myclone
Its .006" with molly lube....not that you cant still call em if you want someone to talk to :p .
4C FED
Absolutum Dominium
Thanks David.
I'm fairly anti-social or so I'm told, so one less phone call is a win in my book.;)
