Eagle Rod Oil Pan Clearance Issues
tbauer03
TRBOBOX
Hey i have heard and read about people having clearance issues with the big end (bolts) of the rods hitting the oil pan and i have done a search and just came up with 2 solutions whack away with a hammer or pay mike lee about 700 bucks for a sheetmetal pan, i am sure it is a nice pan and all but 700 bucks for a oil pan come on what other options are there before i go whacking away with a hammer on my oil pan? Is the stock pan the same has any 4.3L pan with the exception of the turbo return line? I also saw some talk on if you are running 4 bolt mains it could make the fitment better or worse but i was confused on what i was reading on that. I will be running pro gram 4 bolt main caps and a stock crank. Thanks for any replys and i don't want to hear any use the search feature bc i already tried that piece of shit.
What else you wanna hear? Nothing wrong with a little ball peen action.
My buddy Brian Fulop had an asshole(Cal Hartline) build a big$$$ engine, didn't listen to my warning about the rod/pan clearance.... Takes 9 GodDamn months to build it, I get it 1 week before the Nats'02....Finally get the engine started 1 day before they start...... and the F'N' rods are hitting the pan. We gave up and drove my buddy's POS daily driver instead. Just thought I would share :D
If anyone doubts me on this "Buick God" .....Ask Don (raist103) what he thinks about Cal's engine work :fist:
Syborg Twin Turbo
Syborg Twin Turbo
You can contact Guy @ Rockford Racecraft. He has a press that put two very nice depressions in the bottom of the pan to clear the rod bolts. This is the correct way to do it if you don't want to do it with a hammer.
BTW - I bought an engine once that was beaten with a hammer. Man it was discraceful
prosty
The tranny breaker
Sorry a bit OT..
Are Oliver rods better than eagle or what? :)
And if I have my oil pan modded for eagles. Will the Olivers fit?
93ty475
Re: Eagle Rod Oil Pan Clearance Issues
SEARCH!! j/k 8)
you will have a definite clearance issue using eagles or similar rods in a stock oilpan...if the 700 dollar oilpan is out of the question, just do what i did...(get your girlfriend to help)...on an engine stand with the mains facing up, set the oilpan the way it normally goes on, 'without' the one piece oilpan gasket...have her apply slight downward pressure on the oilpan while you turn the crank...that should mark the area that needs to be modified for better fitment...i did it with a hammer and a squarish piece of solid steel...put the area that needs modding over some sort of support like a short fat piece of pipe, so you concentrate the hammer blows just on the spots that need modding...don't hammer on the oilpan without isolating the spot that needs to be dented out (let me know if you don't understand what i'm trying to explain to you)...if you don't do this, you will distort the oilpan, and have to live with oilpan leaks...it took about 59 seconds to do...or you could take it to a machine shop and have them do it...be careful not to scratch the hell out of the oilpan, just mark it for reference...you don't want any unnecessary steel shavings falling into the shortblock...once you get sufficient clearance without the gasket on, you should be good to go...just remember to clean the heck out of the engine and oilpan before you seal up the bottom end...it's very important that you have zero dirt and foreign materials in the motor before you fire it up...the one piece gasket is pretty thick and makes for a decent enough spacer when you're ready to reassemble it...
as far as the 4bolt main caps giving better or worse oilpan fitment, i don't think you will have a problem...mike lee would have tried his caps out and know of any probs before he would sell them to you...i used diamond racing caps and needed no oilpan mods...good luck
tyndago
Dont be a pus-sy about it. Hit the thing with a hammer - its called clearancing....
Not a big deal.... its only an oil pan...
Syborg Twin Turbo
Syborg Twin Turbo
Make sure it's one of those really big Hammers. One with a 3 foot handle. Those make really big dent's They offer extra clearence.
Marty-mj
tyndago
Marty-mj
Come on....... Its a sheetmetal pan. You could cut it apart - extend it and weld it back up.
Nothing different than grinding on a block for rod clearance. Grinding on a head for pushrod clearance.
It only takes a few little dents to clear the rods.
