Eagle rod torque spec
90stangGT
Cobra member
Does anyone know or can double check the eagle rod torque spec?? I seem to have misplaced the sheet that came with them. Also, why are studs installed only finger tight?? Thanks in advance.
sean
Re: Eagle rod torque spec
i have the sheet. if you have a fax # i will fax it over to you
scotts4
ADDICTED
the best was is to use a stretch gauge on the bolts
93ty475
scotts4 said:
the best was is to use a strech gauge on the bolts
No doubt about that....If one is not available, they said it was important to use only the specified "ARP moly lube" on the threads....apparently it makes a difference when you use a torque wrench like we did....
