Eagle Rods CAM clearance
jklein68
I got this question from the guy doing my CAM grind. I'm not sure what the answer is...I am using Eagle H-Beam rods.
"Didn't you tell me you were using Eagle H-Beam rods? If so, are they cam clearanced, or do you need a small base circle cam to make sure the lobes don't hit the rods? I'm thinking you may need a .900" bc cam."
Thanks!
Quickstop [UK]
Combating adversyty.
Re: Eagle Rods CAM clearance
With the eagles you need to clear the oil pan but it's just a dent with a hammer.
Never heard of clear the cam.....
jklein68
Update!
I was able to confirm with Eagle today, very helpful actually, that the rods ARE cam cut. No worries about cam clearance issues. Thanks for your help.
blk00z28
Forced to by choice
Only heard the pan, and a few blocks that need to be cut a little for them to clear.
