cloneman315
i was reding in another post that eagle rods hit on some trucks oil pans is this true?wjhat is the fix for it
DanenGraham said:I think it just comes down to what type of gasket u use. My motor that was built by a machine shop didnt have the pan modded and I never heard it once. But I put a new felpro oilpan gasket in it, it hit like a mofo.
Windedv6 said:Any info on the Canton pan?
John
ghettosled said:i may be wrong but i dont think canton makes a 4x4 pan for the 4.3.. As far as the rods, even with the stock victor gaskets they will hit. best method is bolt the pan on without the gasket, turn motor over by hand, pull pan, look at the marks now left in the pan, dent them good, then put back on with gasket.. turn motor over with hand on the pan to feel the rods possibly touching and hopefully all is well.
James Thomas said:Yea they do, or did. I'll dig up the PN# and post it. Does Victor supply the GM O.E.M. one piece pan gasket? I dono but I have not had to dimple a stock pan with the GM gasket. DanenGraham.... how bout you?![]()
Big Mike said:The gaskets being used are the Victor Renz set # HS5855.
